Thread: Pump Suggestion for 33k Gallon Pool w/Sand Filter - Replacing Pentair WhisperFlo
    SirBrowning's Avatar
    Jun 2013
    Northwest Florida
    19
    So my Pentair Whisperflo WFE-3 - 3/4 HP pump has quit working, new capacitor does not work, when I turn it manually via that nut on the end nothing happens. The external metal housing of the unit is also completely corroded and has turned to powder, so a rebuild probably wouldn't be worth it at this point.
    I am looking for suggestions on a high quality, long lasting pump that saves energy. I have been reading and looking and am pretty thoroughly overwhelmed by the options.
    I have a Polaris 380 Pool Cleaner with the extra pump, so unsure if this makes a difference on the type of pump to get.
    Any pump advice and/or suggestions would be appreciated.
    33,000 gallon, chlorine (3" tabs + liquid shock), Vinyl Liner Pool.
    Thanks!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump Suggestion for 33k Gallon Pool w/Sand Filter - Replacing Pentair WhisperFlo
    I think I mentioned this on your other thread but you could just replace the current motor with a new two speed motor and save quite a bit of money. B2980
    Mark
    Jun 2013
    Northwest Florida
    19
    I'm leaning more towards that, as I could get that 2 speed motor for less than $300 by reusing that skimmer housing part. It seems pretty easy as well according to that video. So is it really a 30 minute job basically?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes for the most part it is pretty easy. It gets difficult when the bolts are rusted or the impeller won't come off the old motor but a strap wrench helps with that. You also need a go-kit
    Mark
