Thread: Slightly cloudy water
    Jun 2016
    Nichols New York
    5
    We set up our pool in the middle of June and up until now I've been able to keep the water In good condition. I forgot to add chlorine to the pool and noticed a slight cloudy look to the water. Tested the water to find chlorine basically non existent, ph was a light high but alkalinity was ok. Treated the water to lower the ph and added chlorine. All levels are good now but still water has that slight cloudiness. So my question is will it clear up eventually if I keep all levels stable ?
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: Slightly cloudy water
    Hello and welcome!
    Do you have a good test kit and can you post some numbers? You should do an Overnight Chlorine Loss Test tonight to see if you have algae growing in there. Directions are at the link but the gist is:
    Let pump run for at least 30 mins after last addition of chemicals.
    After the sun goes down, test FC.
    Before the sun comes up in the morning, test FC.
    If you lose more than 1.0ppm of FC, you need to SLAM the pool.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jul 2015
    Central Valley CA
    1,107
    Not likely, normal chlorine levels are fine to keep algae out of the water but once you get past a certain amount you are at best keeping things the way they are and at worst losing ground. Best to look in pool school at defeating algae And read the directions for SLAM
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
