Results 1 to 7 of 7
Thread: Help! New home owner, pebble tec pool
    Jul 2016
    Victorville, CA
    9
    So im not sure of the gallons, but i have a 16-1/2' x 34' pebble tec 9' deep and 4' in the shallow. Filter is a 450 & 550 Blue haven smartfilter, pump is hayward, i believe. How do i take care of it? Just tested, ph is 7.8, CL is .6, and BR is 1.3. I put 3 chlorine tablets in the float yesterday afternoon
    IG Pebble Tec, 23,900 gal., w/ spa.
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: Help! New home owner, pebble tec pool
    Hi and welcome!
    First things first, you need a good test kit. We recommend the TF-100 from TFTestkits.net but the Taylor K-2006C will work just as well and can be had from Amazon. You need to know what's in the water to know what needs to be put in the water!
    Next, go buy some liquid chlorine aka bleach and take the tablets out of the pool. Assuming they have been used to maintain the pool previously, your CYA is probably way high but we won't know until you get a good test kit and check it.
    Head over to Pool School and read up on Getting Started, ABC's of Pool Water Chemistry, Recommended Pool Chemicals and check out PoolMath at the top of the page to get to know how it works.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jul 2016
    Victorville, CA
    9
    Thanks. Ill let you know what happens. Also, what kind of vacuum head do you recommend
    wjr75's Avatar
    Jun 2013
    IL
    836
    You need to get a good test kit ASAP and suggest the TF-100. I also suggest getting the speedstir. You are going to need to keep an eye on your ph as it will constantly keep rising the first year until the plaster fully cures. I went through 6 gallons of MA the first summer after our refinish.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2014
    Northern IL
    4,615
    As far as vacuum heads go, technique is more important than the head. Go slowly.
    Jul 2016
    Victorville, CA
    9
    I shocked the pool yesterday, now the acid is 7.6 and chlorine is at 5
    Jul 2016
    Victorville, CA
    9
    By the way, after vacuuming and adding chemicals yesterday and beushing the day before, the pool looks great
