Thread: Oops. Been slacking on my pool/spa care
    Nov 2015
    Chicagoland, IL
    205
    I have been testing and adding daily, then I kinda slipped into every other day. Pool still looks and test fine... But the spa is cloudy today! I guess I haven't adequately been mixing that water with the pool water (not testing separately, as there is a spillway we've been running) because spa heater doesn't work, we don't use the spa, but we keep the water circulating. So - should I try and treat the spa separately, or dump it into the pool to mix and kill stuff? I assume I'll need to SLAM it all again :/
    27,000 gal. plaster IG with round spa built in 2007. TFT-100 test kit XL w/ Speedstir
    Jandy CL580 cartridge filter. Jandy 1.0 hp filter pump, 1.5 hp booster/spa? pump.
    Aqualink RS One Touch controls. Paramount PC2000 In-floor cleaning system (1.0 hp pump?). Jandy LX pool heater, apparently broken.
    Missing so much gear due to previous foreclosure, it's sad.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Oops. Been slacking on my pool/spa care
    If you can keep it separate and still be able to filter and circulate the water treat it separately. If you can't isolate the spa water from the bulk pool water then raise it up to slam level and let everything circulate. You have probably caught it early enough to avoid a prolonged slam.
    Love TFP? Become a
    TFP Supporter!
    Nov 2015
    Chicagoland, IL
    205
    I can separate by turning valves, but it still runs though the same pump and filter. I've just decided to treat the pool/spa as a unit. Recent rain is NOT helping. :/
