Results 1 to 12 of 12
Thread: Numbers all crazy. Milky water. Please help!
    Jun 2016
    Batavia
    30
    I have been working on this pool off and on all summer due to some injuries keeping me from really dedicating myself to it. I'm back on my feet and trying one last time to get my pool clear. I have been shocking it and running the filter non-stop. It went from green swamp to now a milky blue with some white foam on top.very cloudy. I ran some tests with my test kit(TF-50). My PH is really low. About 6.2 (I used the ph test strips) and when I went to run my TA the water never turned green. Just turned right to red. When I ran the FC test the water never turned pink at all. I have been shocking it with bag after bag via friends recommendation. I am completely lost and have no idea where to go from here. Please help!
    Above ground round pool 22' diameter 4' deep. 100gpm cartridge filter
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: Numbers all crazy. Milky water. Please help!
    Can you get a full set of numbers from your test kit posted so we have an idea what's going on? Stock up on liquid chlorine if you haven't already because it sounds like you are going to need to SLAM your pool.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    You need to raise your PH pronto. Enter the results in PoolMath, put PH Now at 6.5 and PH Target at 7.2. Add what it says, pump running, brush a little and test in 15 minutes, repeat until PH shows up on the test. It is important to maintain PH between 7.2 and 7.8.
    Jun 2016
    Batavia
    30
    Thanks. I'll be adding borax tonight to raise the ph and going to buy some more shock in order to slam my pool. Just going to keep working on it. Do you think the ph is what's creating that milky water? What else would you suggest?
    30,432
    I would suggest you not buy the "shock" you are buying and buy liquid chlorine instead. The "shock" may be causing your cloudiness.
    To get you up to speed, read "The ABC's of Pool Water Chemistry" up in Pool School. Then read how to SLAM your pool because that's what you need to do next but post your test results first, please.
    DFW, TX
    24,516
    If you are using Cal-hypo "shock" it could cloud the water.
    Jun 2016
    Batavia
    30
    Here are my numbers this morning. I added the amount of borax pool math said and added chlorine to the water as well.
    PH 6.5
    FC 5
    CH 175
    CYA 20
    TA 0
    Anybody have any ideas to give me a hand? The water is looking better each day but still cloudy. i was using the powder shock though. Is bleach the way to go? Thanks
    Jun 2015
    Fairfield Twp, OH
    216
    Do another dose of borax to go from 6.5 to 7.2. What type of chlorine are you using? If it's the powdered stuff, please stop using it and go buy some plain old bleach. It can be the kind from the laundry aisle (no splash-less, scented or outdoor variety, just plain concentrated bleach) from Clorox or store brand that should say 8.25% on the bottle in the ingredients. Or the pool aisle at your favorite big box store should have some liquid chlorine, probably 10%. Whichever is the better deal.
    You'll also want to get some stabilizer to bring your CYA up to 30ppm. A reading of 20 may actually be lower since that's the bottom of the test limit. Using pool math, dose enough stabilizer to go up by 10ppm at a time then test after a couple days and do it again to get to 30ppm.
    Get familiar with PoolMath (link at the top of the page). Put your pool volume of 10,000 gallons in the top left box. The left column is your current numbers. The right column is your target numbers. Hover the mouse over the boxes to see the volume needed. Looks like just over and half gallon of 8.25% chlorine will give you a 5ppm bump in FC and 1lb of stabilizer will give you a 12 ppm increase in CYA.
    Get familiar with the SLAM process as duraleigh said above as you most likely need to.
    DFW, TX
    24,516
    There are at least 4 different kinds of powdered "shock". That is why we often use quotes, because "shock" should not be used as noun in Pool Care because it doesn't actually describe any of the many different products that is labeled "shock". Shocking right!
    More here, Pool School - How to Chlorinate Your Pool
    It is important to keep PH between 7.2 and 7.8 at all times.
    Jun 2016
    Batavia
    30
    So I have been slamming my pool for a handful of days and I'm hitting a rough spot. The water is blue and looks clean but I have little while flakes floating my my pool. I'm talking millions of them creating a cloudy effect. They are too small and not being filtered out. Anybody have any ideas on how to get past this road block? Thanks
    Jun 2015
    Fairfield Twp, OH
    216
    Possibly filter problems. Have you cleaned your filter since you started your SLAM?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Quote Originally Posted by Slyons81 View Post
    SLAM is a process.
    Shock
    Level
    And
    Maintain
    Based on your chorine number above you aren't at shock level for your CYA. You want to raise it to shock level and keep it there testing often to raise it back up. Can you tell us what test kit you are using to test CYA?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
