Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: 1st time pool owner - Drain and refill or filter/clean?
    Jul 2016
    Chicagoland Suburbs, IL
    27
    We bought a short sale property, closed in February and moved in over July 4th weekend. Now it's time to tackle the pool. The previous owners took the pump/filter before they moved out. I'm not entirely sure how long the pool has been empty, but when we first made the offer on the house in August 2015 there was no pool equipment. So the pool has been sitting neglected for at least 1 year, but my guess is close to 2 years.
    Where do I start? Is the pool salvageable? Do I need to drain the pool and start over? Drain some of the water? What is a conservative estimate to get this pool up and running between the pump/filter, test kits, chemicals, and other items needed. $1k? $2k? Looking for recommendations on products, information on pump/filters, or anything I need to know.
    Now for the pictures:
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: 1st time pool owner - No pump/filter and water is black/green
    Welcome to the forum! Looks like you have a project there!! But you are in the right place.
    While waiting for someone to chime in on the equipment, head over to Pool School and start reading. Get a good test kit on order, preferably a TF-100 from TFTestkits.net with the XL option and Speedstir but the Taylor K-2006C can be had from Amazon as well. You're going to do a lot of chlorine tests over the next few weeks, that's why I suggest the TF-100 with XL option. More of the reagents you are going to need.
    Getting Started Go here to learn how to update your signature with all pertinent information on your pool and location.
    Pool School - ABC's of Pool Water Chemistry Learn what chemicals are used and what they do.
    SLAM Because you are going to need to SLAM that green monster into submission!
    I would go ahead and get the cover off the pool so you can get a good assessment of the condition and go stock up on liquid chlorine aka bleach. You're going to need a lot so get 20 gallons or so to start.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Looks like the liner has streched or pulled lose in one of the pics. If I were you I would get the pump and filter first before messing with the water. If your handy with PVC and glue, hard plumb the pipes. If you can save the liner you should be able to get it going for about $1,300 depending on what type of filter and pump I'm guessing.
    This is the filter I have, you could start with something like this-
    https://www.amazon.com/Hayward-S210T...d+filter+combo
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2016
    27
    Quote Originally Posted by JesseSchmidt View Post
    Going to try and get to that on Sunday and take the covers off. Might pick up a skimmer and start skimming out the junk sitting on the surface.
    Quote Originally Posted by banditig View Post
    What happens when the liner stretches/pulls loose? Is that something fixable or would we need a new liner? If it's just an aesthetic thing, I am fine with it looking that way. I should be able to plumb the pipes myself, but if not I have someone who can do that for me. I'm going to try and decide on a pump/filter in the next few days.
    Jul 2016
    27
    I'm thinking a 2HP pump would be overkill, right? Been meaning to measure the pool but haven't had time.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Depends on the capacity of your pool.. I have 13500 gal and my 1hp pump is overkill... turns over all of it in just over 4 hours...
    Quote Originally Posted by cp3 View Post
    Might be able to pull the caps and rails off in that area and take a look... Maybe its just came a little loose and you can pull it back up...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jun 2007
    Long Island, NY
    34
    From the looks of that water, the liner and the grass growing out of the deflated pillow it might be a good idea to just drain the pool, fix the liner and start with a fresh fill.
    Brian
    18' round x 52" vinyl AGP holding aprox. 7633 gallons of crystal clear sparkling water, most of the time. Hayward s166t sand filter, 1 hp pump and 2-2x20 Fafco panels is parallel. TF100 test kit and BBB!
    Jun 2015
    Fairfield Twp, OH
    216
    Did you get a chance to measure the pool? If a liner for your size isn't too expensive, the drain/new liner/refill might be the best option. Did you get a pump/filter yet?
    Jul 2016
    27
    Quote Originally Posted by Macrosill View Post
    I looked under the lid (on the outside of the pool) and the liner seems to have the same amount of overhang all the way around the pool. Not sure if I should try to replace the liner or try to at least get it going for this year and replace the liner next year.
    Just measured it. Been a busy few weeks. The pool is roughly 12'x24' oval and I measured inside depth from the bottom of the pool to the underside of the rail lid and it was roughly 50".
    Jul 2016
    27
    In doing some more reading, looks like my pool is just shy of 7000 gal.
    Thinking this filter/pump might do the trick? I can get 10% off on this: 110 SwimPro Element Filter System with SwimPro Pump - Pumps and Filters - The Great Escape
    Jul 2016
    27
    Also regarding the draining and refilling of the pool. Been reading the dangers of draining a pool and having it collapse on itself. Is there a benefit to draining 3/4 of it and refilling the rest of the way with fresh water? That might be better than trying to just clean and filter the water since it's so bad.
    I know that the water wouldn't be completely clear and I would need some chemicals as well to get the water clean.
    Thoughts?
    Re: 1st time pool owner - Drain and refill or filter/clean?
    I'll take a stab at answering.
    It seems package deals at pool stores usually have a small filter with too much pump
    (a small filter needs to be cleaned more often
    and more powerful pumps use more electricity $)
    I don't think you want a tiny 100/110 filter.
    That said I think the 2-speed version of that kit is sorta acceptable, since low speed uses 1/4 the power.
    I actually received that combo with my free, used AG pool, but I need a seal kit to get it running on my 24' round pool.
    The great thing about the Great Escape is their price on 4 galons of 12.5% chlorine (sold as shock)... And that is basically the only chemical you need (after getting CYA OK)
    I've seen threads here where people get as bad or worse water sparkly clean using the SLAM process. (With mostly that 12.5% chlorine). Don't let them sell you on other chemicals.
    It does seem like you should never let water in a liner pool get below 1 foot, as the liner shrinks and old liners don't expand back. After you get the filter hooked up, I think new water can speed up the SLAM if it's not cost prohibitive.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    OP, please add your pool info to your signature so we can better help you without having to hunt for info. More here on what to put in your signature and how to do it, Pool School - Read This BEFORE You Post
    Jul 2016
    27
    Added my signature.
    Quote Originally Posted by pooldv View Post
    12x24 Oval AG, roughly 7000 gallons. Trying to determine what pump and filter to get.
    DFW, TX
    24,450
    Yep, a 1hp 2 speed pump and a sand filter would be good. Run it on low to filter and high to vacuum.
    Jul 2016
    27
    I was leaning toward cartridge filter. Seems like less maintenance.
    DFW, TX
    24,450
    Yep, that is fine, just get a big one. At least 200 or 300 sf.
    Dec 2014
    Santa Ana, CA
    523
    I'd try to get as much water replaced as I could- God knows what's lurking in there, something like metals would make your life much more difficult.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2016
    27
    Went to the pool store here and had the water tested. They said that the water has a lot of phosphates in the water and that I should drain most of the water and refill it. They said because there is no chlorine in the water that it would be an uphill battle because of the phosphates.
    Here is the printout of the levels. I can drain it most of the way and refill or try to shock and refill. Thoughts?
  20. Back To Top    #20
    Jul 2016
    27
    I might try to drain half or so and then refill it and shock.
