Results 1 to 10 of 10
Thread: Too much chlorine! Help?
    May 2015
    Chandler
    107
    Need some advice after a major screwup. I have stenner auto chlorinator. My power went out & even though the pump says it has batter backup it failed to kick in. So I had to reset my time & timer. I set it to start at 10pm & accidentally set the end time for 1115am & didn't realize it until day 2. The stenner dumped 12 gallons of chlorine into my pool over that period of time. My chlorine ppm is 26. With a cya of 40, what do u recommend? Let it come down by itself? Should I be worried about anything? What's the safe level I can swim?
    14,000 gallon pool, plaster, Pentair FNS 60 DE, Variable speed pump, Chandler, AZ (Phoenix area)
    JoyfulNoise's Avatar
    May 2015
    13,254
    It's ok. Just let it come down naturally. Keep your pumps running. Once you get down to 16ppm FC, it's safe to swim.
    Heck, thrown some pool toys in the pool and use the super SLAM FC levels to clean them up a bit
    Matt
    May 2015
    Chandler
    107
    It's already down to 11ppm. I'm assuming because it me 110 degrees outside & cya is 40 so any ppm above a certain amount will burn extra quick.
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Too much chlorine! Help?
    Yup, the sun here really burns off that excess chlorine quickly!!!
    Enjoy your pool.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Peoria AZ
    57
    I have also noticed my pool eats up chlorine pretty quick past 110* ambient. I have only been in the home for about 3weeks and the few days under 110 seemed to use less chlorine throughout the day. My CYA is still very high 80-85 since I have not been able to dedicate time to correcting that just yet. It has actually dropped some on its own from above 90 I assume from evaporation and refilling of the auto leveler.
    10k gal, IG Plaster, 3/4HP WhisperFlo pump, A.0 Smith Centurion single speed motor, Pentair TritonII sand filter, TF100 test kit, Hayward suction cleaner, City well water
    May 2015
    Chandler
    107
    My CYA was the same until I drained it in February of this year. It stays at 40 now.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    CYA does not get lost through evaporation, however it does break down slowly over time, the speed of this break down is accelerated at higher temperatures. When dealing with Chlorinated hot tubs that are usually kept at 104 degrees F, CYA usually needs to be bumped back up about once per month.
    May 2015
    Chandler
    107
    Mine was 40 yesterday. If it ever gets low I float a couple of tabs.
    Jun 2016
    Peoria AZ
    57
    Quote Originally Posted by Isaac-1 View Post
    good to know. Granted its has not dropped much but it sure has gone down some since I started testing.
    triptyx's Avatar
    Apr 2016
    1,438
    That's huge knowledge there Isaac - thank you.
