Results 1 to 13 of 13
Thread: Green Problem
    Aug 2014
    Texas
    30
    Green Problem
    Good Morning
    I found out yesterday a trace of algae in my swimming pool. I check everyday the pool and do the test. On Monday show that I don't have any Chlorine, so I went to the poolmath input the numbers and I apply what I need to raise my chlorine ( 129oz) ok. On Tuesday numbers was ok. Wednesday is when I found out the algae. So I do all numbers again and this is was my result:
    FC= 6ppm
    CC= 1.5ppm
    TC= 7.5ppm
    TA= 130ppm
    CH= 350 ppm
    CYA=75 ppm
    I know my CYA is high however was form 100+ to 75 that is the actual number.
    Do my math is wrong ? I living in TX and the heat can cause the evaporation of Chlorine plus the high in CYA. Any suggestion will be appreciate. By the way the water is clean and crystal just some part of the wall show the algae.. Thank you...
    14 x 36 In-Ground Fiberglass Pool Free form 14000Gal
    Hayward Super Pump series ( SP2610X15)
    Hayward Pro Series Top Mount High-Rate Sand Filter(S244T)
    Rainbow Lifegard Chlorine/Bromine Feeder ( not in used )
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Green Problem
    The pool needs a SLAM procedure to remove the algae. With your high CYA, this will be difficult, but perhaps doable since you only have a trace amount. Did you test using a Taylor test for CYA? You'd need to raise the FC to 30 ppm until you pass the SLAM criteria to eliminate the algae.
    Isolated Spa - 345 Gallons
    Aug 2014
    Texas
    30
    Re: Green Problem
    Hi
    Yes Im using a Tailor test for my test. I will looking into how to slam the pool. I know is a topic about it, here... Thanks
    Aug 2014
    Northern IL
    4,615
    Re: Green Problem
    Aug 2014
    Texas
    30
    Re: Green Problem
    Thank you!!!
    Feb 2014
    Central Minnesota
    5,080
    Re: Green Problem
    Thanks, Marian! I forgot to type (see link in my signature) in my post!
    Aug 2014
    Texas
    30
    Re: Green Problem
    Update:
    I still working to lower my CYA to address later my algae problem. It's not that bad at all. From yesterday the CYA when from 100+ to 65. I did about 3 time change water just below the skimmer. I have to keep doing that until the number are fine. I know the water bill will be BIG ha ha ha... more to follow..
    Aug 2014
    Texas
    30
    Re: Green Problem
    update:
    After water change yesterday, today the CYA is 47 I only need to do is 15% of water change to hit the 40. Its getting there...
    Feb 2014
    Central Minnesota
    5,080
    Re: Green Problem
    I wouldn't go any lower than you are for CYA. That's a good level for maintenance in your region.
    Aug 2014
    Texas
    30
    Re: Green Problem
    OK... I was told and read that the magic number is 40? I don't have any problem to keep it in that level (47). So you said that for my region it is good ( assume) to have it between 50-45?
    Jun 2014
    15,103
    Re: Green Problem
    ^ I agree. ^ My CYA is currently around 60 with this summer heat. If you're in the 50 ballpark, stop draining now and start your SLAM. CYA of 50 = FC of 20. Run to HEB and grab a bunch of Bravo regular bleach and have a SLAM party.
    Or you can grab Wal-Mart's Great Value or Pool Essentials.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Green Problem
    Yes, 40-50 is good for Texas. If you get an "in-between" number just round up.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2014
    Texas
    30
    Re: Green Problem
    Thank you Texas Splash... I have 8 gallons of chlorine 10%. I will review the SLAM process and do it today..
    Well Mr Bruce ...always I learn in this forum something new, the rules do not applied the same way every time.. Thank you so much for your input...
