Thread: Current switch for SWG
    Jul 2015
    Dayton/Maryland
    83
    I installed intelliflo VS pump and intellichlor IC40. How to turn on/off intellichlor with pump on/off? I did some research on this website and others. I found out that all the designs are over-complicated. Why not just use a current switch only such as this one($21): https://amzn.com/B005CWOAKC? I bought one and will have a try. Any suggestions? Thanks.
    2003 Build 20K gallon salt water gunite IG pool, Taylor 2006 test kit, Pentair 011018 IntelliFlo Variable Speed Pump, Pentair IntelliChlor IC40 SWG, Aquabot ABTTJET Turbo T Jet Robot
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    Re: Current switch for SWG
    Looks like it will work to me. Keep us updated as to your findings..
    I think most people that have the Intelliflo and IC40 also have an automation system to take advantage of the Pentair products abilities, but plenty of people have added a VS pump and would be interested in finding a cheap way to sync the pump and other items.
    Thanks for posting.
    Jul 2015
    Dayton/Maryland
    83
    Thanks. I think even there is automation system, current switch is more reliable because it is much simpler.
    Quote Originally Posted by Jimrahbe View Post
    Thanks for posting.
