Thread: Push/Pull Backwash Piston
    May 2015
    Dayton, OH
    17
    I have an old push/pull backwash assembly, and I believe the internal O-ring is leaking. I'm going to replace it, but I also noticed that the 2nd piston is moving freely. Is this normal, or does it need to be stationary? Seems to me like it could just slide to the other piston and cause problems, unless something inside the backwash valve stops it..
    20,000 gal oval pool
    Vinyl Liner
    Sta-Rite Sand Filter
    Hayward Pump
    Jun 2014
    15,298
    Re: Push/Pull Backwash Piston
    dw, I saw your post a few days ago but honestly I wasn't sure about that piston in the middle. I was hoping some others with your set-up might have responded by now. Your thread has sat for a while to where I didn't want you to think we were ignoring you. Have you resolved or gotten a good answer to your question?
