Thread: What are the proper filter settings when vacuuming??? Pump basket full..confused.
    May 2016
    Toronto
    130
    Hey,
    Before I vacuum, I try to remove most big leaves manually.
    Currently, when I vacuum, I just connect the vacuum to my skimmer, and leaver the sand filter on "filter" mode. When I vacuum, I maybe collect like 10-15 leaves..is this bad?
    Where do these leaves do? To my filter or to my pump basket? Not sure because yesterday I opened my pump for the first time in like 3-4 weeks, and there we ALOT of leaves in there. Is that from the 3-4 times I vacuumed?
    Should I continue to vacuum in "filter" mode and then backwash once PSI gets high? Or should I be vacuuming in waste mode? If so, same idea of connecting it to the skimmer right?
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Re: What are the proper filter settings when vacuuming??? Pump basket full..confused.
    Does your skimmer have a basket? If not, get one and it will catch them before they get to the pump. But after vacuuming, it's a good practice to empty the skimmer and pump baskets. And yes, running the pump on regular filter mode is correct unless you have a swamp situation and are trying to get rid of lots of junk.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
