Results 1 to 8 of 8
Thread: My pool has a PH of 7.2?? Do I need to get it up to 7.5?? SWG!!
    May 2016
    Toronto
    129
    Hey,
    I have a CYA of 80 and FC of about 5.5-6.
    Just tested PH and it said 7.2
    Is that too low?
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Re: My pool has a PH of 7.2?? Do I need to get it up to 7.5?? SWG!!
    Since you're running a SWG you're OK. Your SWG will bring it up in time
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Is it just out of the recommended level, but not detrimentally low. I expect you are getting ready to run the SWG for the day (unless your chlorinate at night) which should bring it up. If I were you, I would just keep an eye on it and do a few cannonballs.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2016
    Toronto
    129
    Quote Originally Posted by Pool Tool View Post
    haha thanks.
    I do chlorinate at night. I usually run the pump from 7pm-7am (lower rates) and chlorinate at 60% output.
    Why does pool exiting the water increase PH?
    May 2015
    Land O Lakes, FL
    527
    What kind, model of SWG do you have?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    May 2016
    Toronto
    129
    Quote Originally Posted by mgmoore7 View Post
    Jandy (zodiac) Aquapure EI.
    Pool Tool's Avatar
    May 2014
    757
    Why does pool exiting the water increase PH? I mimic only what I read as its over my head to fully understand, but pH is raised by the outgassing of gases in the water namely CO2. By aerating the water either by splashing around or cannonballs this speeds up outgassing and the pH inherently rises towards equilibrium. A SWG further adds to this by augmenting gases in the water with production of chlorine gas. As such, many SWG pool owners have to pay attention to their pH rise and TA levels. Lower TA levels can help reduce outgassing and slow pH rise.
    May 2015
    Land O Lakes, FL
    527
    Depending on your daily loss of FC, you may not be or on the brink of running your SWG long enough at 60%.
    Matt
