Results 1 to 7 of 7
Thread: new to the pool ... Help with Baq
    Jul 2016
    hammond indiana
    3
    suggestions anyone
    hello, im new to the pool, i just bought the house it has an above ground pool which is 15 by 48 also 5000 gallon im useing baquacil and my water is very cloudy? how can i clear my water i added algea and santizer and 6 oz of ph increaser, what am i doing wrong? should i get rid of baqacil and go to chlorine? i just want something low maintenance an easy to figure out....
    Jul 2016
    hammond indiana
    3
    help
    i have a 15 by 48 pool which is 5000 gallon and cant get my water clear, i added ph increaser and aligstat and algea.
    Jul 2016
    hammond indiana
    3
    i have a 15 by 48 5000 gallon pool that i cant get the water clear im useing baquacil.
    38,548
    Re: new to the pool
    Welcome to TFP!!!
    I am going to move this over to the related forum area ... as Baq is kind of its own beast.
    Apr 2014
    Hackettstown, NJ
    35
    Re: new to the pool ... Help with Baq
    Others will be along shortly, I don't have personal experience with baq, but from what I've seen and read, you're in the right place. Are you here to try to get your baq cleared up, which I've read can be done, or perhaps you're at wits end with it and considering going to the much easier and cheaper chlorine?
    25.5K gal vinyl IGP 3.5' - 8' depth. 1.5HP single speed A.O. Smith C48L2N134B1 motor on a Hayward SP2610X15 Pump. 40 ft2 D.E. Filter Hayward model EC75A. Hayward Chlorinator model CL200. single skimmer, 2 Returns. TF100 Test Kit/Speed Stir.
    38,548
    I just noticed the small size of this pool. Honestly, your best bet is likely to drain it and start over, either with Baq (not recommended) or with chlorine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: help
    Welcome to TFP!
    If you plan to take it down at the end of the season then I would follow this
    Pool School - Guide for Seasonal/Temporary Pools
    If not, then start reading here
    ABCs of Pool Water Chemistry
    And here
    Pool School - Getting Started
    EDIT: disregard this response. The post I responded to did not indicate that baquacil was in use. Please add your pool info to your signature so that we can better help you. More here, Pool School - Read This BEFORE You Post
