Thread: Can't keep any Free Chlorine
    2 days ago I Shocked with 2 #'s of shock, tested today and the FC was at about .5 I added 2 .5 qts of 6% bleach this morning, tested in the evening and the FC was still at about .5 Whjat could be eating up all my chlorine.....The pool is 17,000 gallons, ph at 7.4 and CYA was at 0 but added conditioner 1 day ago, so it should be coming up....
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    Re: Can't keep any Free Chlorine
    When the CYA level is very low, you can lose all of your chlorine to sunlight in less than a day.
    Algae can consume all of your chlorine quite quickly.
    Also, sometimes when opening in the spring there is a substantial chlorine demand for a while.
    What does your water look like?
    It is fairly clear....
    Salt Water
    Sand Filter
    With clear water there probably isn't any algae. Still, the 2# of shock you added would have be consumed by sunlight. That means that all you really lost was 2.5 qts, which really isn't all that much chlorine, perhaps 3 ppm at most.
    Regardless, the solution is more chlorine. You need to keep adding chlorine until you can maintain a FC level.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Perhaps it has something to do with your recent Absorbic Acid treatment.
