Thread: Pressure test???
    Jun 2016
    St charles
    28
    Pressure test???
    I'm am plumbing a pool and I need to know how to pressure test my fittings. Can someone give me some guidance??
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pressure test???
    from what I have seen you just cap the ends and one end use a union connected to a pressure gauge and take everything to I think 25 PSI.. I have seen someone post a kit before that they used...
    here is a setup from a company
    Jun 2016
    St charles
    28
    Quote Originally Posted by cowboycasey View Post
    So I used a tubeless stem in a cap and sealed off other ends. Pumped with air from compressor and brought it to 20 lbs. (checked with tire gauge). Checked about an hour later still at 20 lbs. a coupling is cheap compared to some of the stuff needed in that video. I have a 2" and a 1 1/2 that's on a male threaded for my jets. Problem solved
    Jun 2016
    St charles
    28
    But I thank you very much for your helpful input. Love this board!!!
    Jul 2013
    Fletcher, OK
    3,353
    I really like your way, nice and easy
