Thread: My socks are yellowish green
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    87
    The last few days my skimmer socks have turned a yellowish green but my water is clear and no signs of algae in the pool.
    My pool is surrounded by trees and wondering if that is pollen in my socks, or the first sign algae?
    Latest test results
    Fc 5
    CC 0
    TA 90
    CH 150
    ph 7.6
    CYA 40
    SteveS
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: My socks are yellowish green
    Sounds like pollen. You can do an Overnight Chlorine Loss Test to be sure.
    May 2016
    87
    Past the OCLT so will conclude it is pollen...thanks Poolv.
    SteveS
