Thread: Fresh fill - not registering chlorine
    May 2016
    Oshawa, Ontario, Canada
    26
    I have a new pool... Been filled for 10 days. It's been 95F ++ humid and sunny for weeks, all sun, no rain. I have not had the pool covered either.
    I have no test results other than a strip test... I have ordered a proper rest kit though.
    Water is crystal clear and have had a robot cleaning it everyday.
    I can't seem to register any chlorine on the strip... One day it's low, then almost nothing.
    Is the sun burning up all the chlorine?? It can't be an algae problem so soon, can it??
    I've cranked up the auto chlorinator to full just now to see if it makes a difference. It was on the half mark.
    I'm using bioguard smart sticks (from the startup kit) in the chlorinator. I also dumped in the pool, 1 bag of bio guard smart shock (from the start up kit) 3 days ago.
    New Pool Build July 2016
    Taormina In Ground (steel/Liner) 17,100 Gallons. 16x20x32
    Hayward SP3200VSP 1.8THP Pump
    Hayward Pro Series Sand Filter S-220T
    Hayward Chlorine Feeder CL200EF
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Fresh fill - not registering chlorine
    Sounds like the sun is burning it off. At least that would be a better reason than something growing in the water.
    The problem is is that we do not recommend the routine use of chlorine pucks/sticks/granules as they add unwanted extra ingredients that build up and cause problems.
    Please read this:--> ABCs of Pool Water Chemistry and this too... Pool School - Recommended Pool Chemicals
    Let us know if you have further questions
    Yip
    May 2015
    Land O Lakes, FL
    527
    You are going to need to kit a good test kit for us to help you: TFTestkits.net
    Has any CYA been added yet?
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    May 2016
    26
    I've ordered the Taylor K 2006 kit, hopefully see it in a few days...seems to be one of the go to test kits?!? Being in Canada the kits are extremely difficult to find.
    No Cya has been added, expect for a starter 1lb pack of bioguard smart shock...
