Thread: Concrete sealer around old pool?
    stevenmverrill's Avatar
    Nov 2015
    Frederick md
    30
    Wondering if any one has a prefred product, or the same struggle as i?
    My main source of sinking debrees is sand, fowlling every party. The sand is coming from foot traffic of 20+ year old concrete.
    Thinking a sealer product will help keep it together and out of the pool. Thoughts?
    18x36 rectangle built early 90's, 9ft well, "black onyx" vinyl liner, 1 1/2" plumbing, 2 returns, 1 skim, 1 drain/return, plumbed chloranter, 48sf de filter, multi port valve, and 1.5hp jandy pump.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,803
    Re: Concrete sealer around old pool?
    Use a product similar ( there are a few like it ) to the one below. It goes on as a watery opaque liquid and will drill clear/glossy, you can generally apply it with a pump garden sprayer or roller brush. It will seal the surface porosity of the concrete and help prevent any more sand from getting loosened out of the surface. I would strongly recommend a good pressure washing of your deck prior to applying the sealer. Any stains or discolorations left on the surface of the concrete will be near impossible to remove once the sealer is applied.
    Shop Seal-Krete Clear Seal Gloss Sealer (Actual Net Contents: 128-fl oz) at Lowes.com
    If you are looking into a colored option like a paint or epoxy I'm not very familiar with those.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Nov 2015
    Frederick md
    30
    No perfect. Thanks,
