Results 1 to 8 of 8
Thread: Need help with level reading
    Jun 2016
    Center moriches
    23
    Just tested my water. I have an FC level of 4 and a CYA level of 45/50. Pool is very clear. SWG is currently operating at 40%. Ph is 7.6. Is my CYA level good? I tried reading the chart on the site, but wanted an experts opinion.
    24,000 g salt pool, intellichlor IC60 SWG, L-shaped IGP, Pentair Superflo VS pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Need help with level reading
    If you raise your CYA, you may be able to lower the SWG setting which will help extend the life of the SWG cell. 80 ppm is usually recommended for SWGs because of this reason.
    Mark
    Jun 2016
    Center moriches
    23
    I just put in 2lbs of granular stabilizer. Should I lower the SWG to 20%?
    mas985's Avatar
    Pleasanton, CA
    11,737
    How did you add the stabilizer? 2 lbs only adds 10 ppm so not much of a change. You shouldn't lower the setting to less than 35%.
    Mark
    Jun 2016
    Center moriches
    23
    Straight into the skimmer. I just added 4 more pounds of stabilizer. I will retest levels in a week?
    mas985's Avatar
    Pleasanton, CA
    11,737
    In the filter can take longer. What type of filter do you have? Just don't backlash.
    Mark
    Jun 2016
    Center moriches
    23
    DE filter. This should bring my levels to 80ppm for CYA. Should I raise my SWG or just play it out?
    mas985's Avatar
    Pleasanton, CA
    11,737
    What until the cya tests to 80 ppm. It could take several days.
    Mark
