Thread: Rope Anchors and "What the heck is this?"
    jameslcobb's Avatar
    Jul 2014
    Elizabeth City, NC
    7
    I have these brass rope anchors and one is broken and the other is missing the screw on attachment. Anyone know where I can get parts for these?
    I also have four clamp type brass pieces that I have no idea what they are. Help?
    20' X 40' 36,000 gallon vinyl in-ground pool
    Pentair sand filter
    Hayward 1 hp Super Pump
    TFT 100 test kit
    installed 09/1984
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Rope Anchors and "What the heck is this?"
    The bottom picture is a ladder / railing wedge for securing them in the mounts. It don't have a clue what the top picture is.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    If you are going to use the wedges, replace the bolts and washers with stainless steel. You can get them at any hardware store or Lowes / Home Depot. If the existing bolts do not unscrew, soak them with Nut Buster or other penetrating fluid for 30 minutes or more. WD40 will not work. If the soaking does not work, you can use a propane torch to heat the wedge for 30 seconds or so. Try the bolt, heat again if necessary.
    Steve
    jameslcobb's Avatar
    Jul 2014
    Elizabeth City, NC
    7
    Thanks... I've got some PB Blaster.
    Pentair sand filter
    TFT 100 test kit
    installed 09/1984
    jameslcobb's Avatar
    Jul 2014
    Elizabeth City, NC
    7
    I figured out what anchors these are. Perma Cast P172B. Ordered some online but not sure if I'm getting one or two.
    Pentair sand filter
    TFT 100 test kit
    installed 09/1984
