Results 1 to 10 of 10
Thread: Buying reagents
    Aug 2015
    ny ny
    24
    Buying reagents
    I have the Taylor kit that everyone recommends but I'm running low on the chlorine and cya reagents. Where do you buy them from?
    33000 gallon vinyl IG pool. s240 hayward sand filter. Full sun in NY area.
    Aug 2014
    Houston tx
    2,525
    Re: Buying reagents
    TFTestkits.net
    You can get them where it says TF-100 refills.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2015
    ny ny
    24
    Re: Buying reagents
    Is this the best price to get them? Or has anyone found a cheaper alternative
    38,539
    Re: Buying reagents
    It may not be the best price, but it is the best customer service and is tangentially affiliated with the forum.
    Aug 2014
    Houston tx
    2,525
    Re: Buying reagents
    They also are quick to ship and arrive! Mine came in a couple of days but it probably is dependent on where you live.
    Marla
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Buying reagents
    And always fresh and guaranteed.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Buying reagents
    TFTestkits.net................Best customer service around and very fast shipping
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jul 2015
    Central Valley CA
    1,109
    Re: Buying reagents
    I just did a quick check between Amazon (the only other place I know to get reagents) and tftestkits.net and it looks like TFTestkits is in fact less expensive even with shipping. The only way I see to get the price lower is to buy large amounts and I am not sure that is a great idea unless you are using them on several pools and will use them up in a year or two.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Buying reagents
    Remember everything is not about price, with reagents you also need to be concerned about how fresh they are and their storage conditions, buying from TFTestkits and you don't have to worry about them being stored in some hot / cold warehouse next the cat litter, etc. like you do with the big online retailers.
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Re: Buying reagents
    I bought several things including reagents from VMInnovations, they sell through Amazon but are a little cheaper through Ebay. Everything has been delivered quick and fresh with free expedited shipping. They are located in Lincoln, NE only about 120 miles from me so it gets here fast, think they use priority mail anyway. I bought R-0870 in .25 lb, R0871 and R-0013 in the 16oz size because the small 3/4 oz size seems ridiculously overpriced, for about twice as much money I have 20 times more. I also have a friend and a brother in law both with pools so I can share.
    I test a couple times a day and always use the 25ml sample, so I use a lot, I like the added accuracy. The 870 and 871 has expiration dates of late next summer and the 0013 is spring of 18 so they will get me through next year too. As far as the powder, I don't believe it significantly degrades no matter the date. A quarter pound is significantly more than the tiny little 10 gram size. I have read several on here using it for 3-4 years with no difference from fresh, even clumpy and crusty it still worked just the same. I'm transferring it into the 10 gram container as needed, then sealing the big bottle back up in a vacuum sealer bag.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
