Results 1 to 7 of 7
Thread: Anywhere to buy a salt test kit locally in San Jose?
    Jan 2015
    San Jose, CA
    237
    I see leslie has one but not what TFP recommends. Need to install my SWG tomorrow but don't have any salt test kit on hand. Amazon won't ship for 4 days for the Taylor kit and even aquacheck are not available to ship for 4 or 5 days.
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    38,547
    Re: Anywhere to buy a salt test kit locally in San Jose?
    You could just let the pool store test it initially while your kit is on order. And then aim a little on the low end when you raise the salt level.
    Jan 2015
    San Jose, CA
    237
    Since I have no way to test it now, for a 20k gallon pool, I'll need something like 570lbs to bring it to 3400ppm. is it safe to dumb 300-400lb in tonight and go measure it tomorrow @ the pool store?
    SF Bay
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    I'd aim for about 2600 ppm first time. It takes 24-48 hours for it to fully mix into the water.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    For salt.....I have found the Aquacheck strips to function well. I know I've picked them up at Lowes In the pool section. Tftestkits.net sells them as well. I know we preach no strips but this isn't a color matching strip and generally performs well.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    38,547
    As long as you read the strip instructions and use them correctly (NOT submerging the entire thing in water) the strips to ok.
    Jan 2015
    San Jose, CA
    237
    I'm going to head to lowes to find me some check strips and pick up some salt
    SF Bay
