Thread: Changing Pool Light
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Changing Pool Light
    I just found out my pool light wont go on. Haven't really tried it in over 6 months mostly because it's so bright like a train coming at you glaring right in your eyes, so we usually just leave it off. I would like to go to a much less brighter one because of where it is located in the pool facing the Lanai where we set.I was thinking about one of those color changing led ones.
    I found one on Amazon for 61 bucks as opposed to several hundred I've seen at other places.
    I'm hoping its only the bulb that is out it seems fairly easy enuf to replace and I'll get a new gasket too the one on there now was leaking a little or condensation I think from the little bit of green i see on the inside at the bottom of the lens.
    Has anybody here ever tried one ? Did It work and last OK ? If not any suggestions would be appreciated!
    Thank you All for this Great site!!
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Changing Pool Light
    If you could post the link to the specific bulb you found, that would help. Perhaps others have purchased the same.
    In general, LED lights don't put out as many lumens as the 500W incandescent bulbs, so you'll likely be happier with the light output from the LED, especially a lower priced one with less LED emitters.
    Isolated Spa - 345 Gallons
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    Thanks JVTrain I guess that would help here's the link
    Amazon.com : 120V Color Changing 18w Replacement LED Swimming Pool Light Bulb for Pentair Hayward Light Fixture : Swimming Pool Lighting Products : Patio, Lawn Garden
    Since my pool is so small this might be just what I need or just get a smaller watt white bulb,but it might be more fun to have colors!
    So if anyone on here has tried this light I would appreciate any comments.
    Aug 2015
    Orlando
    116
    Thanks SGT, was looking for something other than my 'train headlight' PB installed. I never thought about it when we bought the house, PB never suggested alternatives to their 'standard package' and didn't want to replace the entire 100' cable and housing!
    Thanks for asking about it. I read all the Q&A looks like it will work for me.
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
