Thread: I think I have algae IN my ladder.
    Jul 2014
    NJ
    46
    I have cloudy water and failed the Overnight test, so I am going to SLAM. I believe the algae is IN the ladder because I am pretty strict about watching the Chlorine levels. I always brush the stairs, but I dont think the water that is in the ladder gets circulation. Here is my question: Can I just pour bleach into the ladder hole, that has water in it? If so how much bleach? I realize that I should take the entire ladder out and do it, but my husband is away on business and wont be back for a week, and I cant do it on my own. For reference I have the Confer A-Frame Above Ground Swimming Pool Ladder. Thanks for any help you can give.
    5,700 gallon, Carribean Isle 15x52 Round Above Pool.
    Cartridge Filter.
    Installed Fall, 2014.
    North New Jersey
    Using the TF100 test
    Jun 2014
    15,239
    Re: I think I have algae IN my ladder.
    Yes, ladder steps can definitely harbor algae. I recently saw another poster who used a syringe to inject some bleach into each step/rung. In his case, he mentioned that the bleach is slightly heavier than water so it will tend to sink. He also said it didn't take much in each step. He seemed to be pleased with the outcome. But yes, ladders can provide a surprisingly good home to algae if not cleaned/bleached periodically.
    Jul 2015
    Charter Oak, California
    273
    The Confer 7200 we have has a closed water system for weight in the legs and not open to the pool water (I fillwd them with the hose and added chlorine inirially), so on occasion I'll add liquid chlorine to the fill holes on each side. The steps however are exposed to pool water but there can't be much circulation since the holes are so small so I'm going to have to use some type of syringe or Turkey baster to push a little chlorine through them as well..
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
