Thread: First opening after 4 years...going the TFPC way...but what order?
    Jun 2016
    Wichita, Kansas
    5
    After a two month struggle, finally got the pool cover repaired and saw water for the first time. I was expecting a swamp full of frogs and unwanted growth. Surprised when it was slightly green and only leaves. Water test was:
    FAC - 0
    TAC - 0
    CH - high 460
    CYA - Low 25
    TA - High 150
    PH - 7.8
    I'm on well water and am fortunate that the iron and copper levels came back at 0.
    I'm wondering if I have started and am following the proper order in getting things balanced.
    Starting with the TA. Started adding Muriatic Acid and is now circulating.
    Once that is where it needs to be, recheck the PH. If they are acceptable then move on deal with the Calcium Hardness. I don't really want to drain anything out. Is it okay to leave the calcium alone? I'm only getting the pool ready so we can put the house on the market.
    If its permissible to bypass the CH, I'll move on to the FAC, followed by the CYA.
    Is this the correct order to follow? Any suggestions or recommendations?
    Thank you in advance for your help.
    Last edited by Toomchtodu; 07-20-2016 at 12:47 PM. Reason: forgot to include iron and copper levels for well water
    Toomchtodu
    and never enough time.
    40K/IG/Concrete/Crystal Water DE?/Zodiac LM3 40/25-30 years old/Taylor DPD/Polaris Cleaner/Well Water
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: First opening after 4 years...going the TFPC way...but what order?
    Don't worry about TA just yet...
    Start with the chlorine...gotta get that algae dead...Crank it up to about 9FC. Keep cleaning the pool and get out all the muck
    PH will come down with the addition of MA
    You can target 30 CYA with slam levels but 25 is a bad reading... cant really tell that low...IF the water is a little cloudy, you know some may be in there...not sure how much
    You can Slam now if you like... IF it were me, I would add enuf stabilizer to go from 20 to 30 then target 40 for slam
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    You correct order should be:
    FC then pH (pH is near the high end but fine @ 7.8)
    CYA - get to atleast 30-40
    CH is good enough and TA is something that you can alter with changes pH. High TA itself is not an issue, but it can have a tendency to encourage pH to raise quickly.
    These all look like pool store numbers, so use caution as they can be poor at best most of the time. Since you are selling, buying a test kit may not be in the budget. But it would be a nice house warming gift.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jun 2016
    Wichita, Kansas
    5
    Those were the pool store numbers but my tests, using my new Taylor DPD kit were:
    FC - 0
    TC - 0
    PH 7.8
    Alk - 200
    Toomchtodu
