Page 1 of 10 1234 ... LastLast
Results 1 to 20 of 192
Thread: Got my kit...first readings
    aguyindallas's Avatar
    Apr 2016
    Little Elm, TX
    127
    Ok, my kit just arrived. I am starting my first water test.
    CL - Appears virtually undetectable in terms of color.
    Ph - Very pink...more pink than the highest 8.2 indication.
    When trying the Free Chlorine Test, I added 30 drops of R0871 and it never got fully clear. It went from pink to opaque white, but never clear. Not sure if I needed to keep going and add more or stop.
    When trying to do the calcium hardness test....again, I added 25 drops and it never got blue.
    When doing the total alkalinity, I added several drops and the test solution never changed. Eventually the actual drops did change to red but the overall solution never did. Am I doing this right?
    CYA appears to be about 75.
    I am a bit intimidated about this...and not sure if I have been doing the first test right. I need to understand if I am supposed to be looking for total color change in the test solutions or just add drops at test chemicals until the actual drops change color for a second or two.
    11.5K Plaster, level spa, Salt with Pentair Equipment.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Got my kit...first readings
    Total color change... Drops until the color changes no more... Then use the number of drops prior to the last one without a change
    FC will go from the lightest pink to completely clear within a drop
    PH way high.. Add MA to go from 8.2 to 7.5 then restest after about 30 min of circulation
    HOw much bleach have you added recently?
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Apr 2016
    Little Elm, TX
    127
    I did the PH test twice with two different kits. It was clearly too high. I just added .5 gallon roughly of MA. Waiting for a little longer before I retest. About to turn on waterfalls to increase circulation.
    May 2016
    Phoenix AZ
    128
    You'll get the hang of it. It's a little intimidating at first.
    I keep a jug of distilled water to rinse out the vials between tests. That way I make sure there's no reagent contamination from previous tests.
    With the FC test, it's the color change from pink to white that you're looking to see. The water will be a bit cloudy from the powder, so clear is misleading.
    For the TA test, you will see flashes of red as you add drops. What you're looking for is for the whole vial to turn red. Same with the CH test, except you're looking for blue.
    Once you've done one successful round of testing you will learn to trust your numbers.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    Jun 2016
    Boston burbs, MA
    45
    It took me a couple weeks (and finally a Speed Stir!) to really be comfortable with the process and my results. Just keep testing and you'll get it! Watch some videos too!
    Good luck!
    Rhonda, Outside of Boston, MA
    20k gallon IG gunite circa 1984, very old/stained/worn out plaster finish
    4820 Hayward DE filter, no idea on the pump... will figure that out!, T-100 test kit, Speed Stir is the BOMB!
    *Researching options to refinish Spring 2017!*
    Apr 2016
    Little Elm, TX
    127
    Ok, with some of the above knowledge, I'm about to start another round of tests.
    Apr 2016
    Little Elm, TX
    127
    Well....PH still a bit high. It did come down with the added MA from earlier. I just added some more and will retest in a little while. The CH is still on the lowest end of the spectrum and barely detectable. Should I do anything there right now, or wait until the PH is under control? My Salt system is set at 30% output according to Screen Logic and I am at 3300PPM salt. Once I saw the PH where it was, I did not attempt any other tests.
    Just to be clear, I don't have any obvious issues at the moment. I am just testing and learning.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Don't worry about CH at the moment... your most important tests are FC (powder) PH (R-0871) and CYA (black dot test)
    Since you have an SWG, CYA seems in the normal range
    Your target Fc for normal operations is 6. Don't let it get below 4 for sanitation reasons...
    Try your FC test again and see what you come up with... Should be 12 drops at the 10ml mark
    If you FC level is over 10, your PH results will be inaccurate. Starting to see how all these tie together?
    13500 gal
    Apr 2016
    Little Elm, TX
    127
    Ok, so I did the FC test again. Got barely pink, but I can see the difference. Only took 2 drops to turn the water white again...meaning 1ppm. It only took 1 drop of R0871 to get the color right again, so this means .5ppm...giving me a total FC of 1.5ppm...correct?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    YEs but we don't count total... Doesn't mean much...
    FC- 1
    CC - .5
    Which means you need chlorine... yesterday....
    Check with pool math to find out how much exactly... prolly close to a gallon to get up to at least 6.
    Since you have CC, that means something is in the water..ie ALGAE... I would shoot for 9 FC which will keep your PH tests relevant and give you a head start if you have to slam.
    13500 gal
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Oh yeah... If you do have algae, your SWG isn't keeping up as the algae and sunlight will consume your chlorine.. Never ending battle
    13500 gal
    Apr 2016
    Little Elm, TX
    127
    So should I get tablets or add chlorine liquid?
    Apr 2016
    Little Elm, TX
    127
    And FYI, the water is very clear.
    May 2016
    Phoenix AZ
    128
    Quote Originally Posted by aguyindallas View Post
    At this point, use only liquid chlorine or bleach, with a known strength and recent date of manufacture.
    ETA: most tablets have CYA in them, and you don't need to add any.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Bleach will suffice... straight from wal mart.. I use Great Value 8.25%
    Say bye bye to tablets unless you go on vacation...They are way to slow to keep up and introduce CYA into the water.. you don't really need your CYA levels skyrocketing...leads to more chlorine usage and eventually a water change.. Something the Pool stores don't tell you...
    13500 gal
    Apr 2016
    Little Elm, TX
    127
    Ok....off to Wal mart. Lol. I assume just pour this directly into the deep end, near one of the returns?
    Apr 2016
    Little Elm, TX
    127
    Added 1 gallon of bleach. How long before I retest?
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Just in front of the return so it disperses...
    Test about 1/2 hour after addition
    13500 gal
    Apr 2016
    Little Elm, TX
    127
    An hour after adding a gallon of bleach.
  20. Back To Top    #20
    Apr 2016
    Little Elm, TX
    127
    FC is now 7
    CC is .5
