Thread: Internal leak?
    May 2016
    Arizona
    6
    Internal leak?
    After adding a skimmer the pool started to leak. Even on hot days we see water on the ground in one area which is opposite the skimmer. Never prior. Yet I see no obvious signs of leaking anywhere. Im going to try the dye leak detection however I am curious, is there such a thing as leaking witing the layers of vinyl? Im thinking if I do not see any water from the outside the leak must be on the bottom somewhere....thoughts? Thanks.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Internal leak?
    As a new, non-contributing member, storage space for attachments on the website is very limited.
    It's best to share photos by uploading to an image hosting/sharing sight and link them into your posts from there. See how here: Posting Photo's Tutorial
    Isolated Spa - 345 Gallons
    30,413
    Re: Internal leak?
    If you have a continuous wet spot, you have a leak. How much does your pool water drop daily?
