Thread: Re: Newbie
    Deeannw's Avatar
    Jul 2016
    Bellevue Nebraska
    13
    Re: Newbie
    Hi everyone I'm a newbie to owning a pool I researched my purchase for over a year and finally bought one online. It's an above ground 24x52 and then after getting it put up my mind went blank regarding chemicals. It's rained every night and then I took a water sample to my pool store and he said to shock it and I left the pump and noticed the shock has settled to the bottom of the pool. I used the brush several times during the day and there is still a little shock settled on the bottom of the pool. Any suggestions? And I'm definitely going to use the BBB method after reading about E-Z pool. Thank you!
    24x52 round AGP 14750 gallons 19" Hayward sand filter w/1 hp pump Polaris 65 vacuum sweep (Hasn't worked since purchased) Transitioning from Strip test to Leslie's FAS-DPD 81329
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Newbie
    Welcome to TFP!
    Congrats on the new pool! Do a little reading in Pool School.
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    You will need a great test kit to take care of your pool. I use the TF-100 and I buy it from TFTestkits.net. It is the best value, here's why, Pool School - Test Kits Compared
