Thread: my results
    Jun 2013
    Cypress tx
    9
    my results
    Hello friends. Got the new test kit in so gave the water a check. I have been using and adjusting the water on an several year old leslies pool test kit that checks for ph and chlorine.
    here is the results from yesterday
    FC-5.5
    CC-.5
    Calcium hardness- 425
    Cya- 80
    ph-7.2
    Total Alk 110
    the Ph was high this past week 8.5 so have been working to get it down, I think at least 1 gal of acid. got the ph down and the cya got low so added 2 lbs of baking soda to get it up to the 80.
    the above results are using the new tf100 kit.
    pool looks great, had some cl2 issues but after about 3 gallons of bleach finally got it up.
    1 question I have is about how much bleach, (10%) should I add every day to try and stay steady on the numbers?
    South texas heat and pump runs about 8 hours.
    Michael
    20000 gal
    in-ground plaster, replaced early 2015
    Cartridge filtration,
    single speed pump
    well water
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: my results
    Going to have to experiment.... Could be half gallon, could be more.. All pools are different.
    Try testing a few days in a row at the same time of day to see whats going to happen..
    I add about half gallon every 2-3 days depending on FC level...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Jul 2015
    Central Valley CA
    1,109
    Re: my results
    From the posts I see from TX it is not unusual to loose 1.5 to 4 ppm per day with 3 being the norm. As cj373 said every pool is different but being in TX I would expect you will be adding daily. Your CYA would be high for many but is good for TX you just want to be diligent making sure your FC never gets below 6 ppm as slaming with a CYA of 80 is not fun should it be come needed.
    edit corrected early morning pre coffee mistake,
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2015
    Chandler AZ
    935
    Re: my results
    Baking soda - addition raises TA
    Stabilizer/conditioner/cyanuric acid - addition raises CYA
    Exactly what did you add? How much did you add?
    You can use Pool Math to calculate the amount to add based on your test results.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jun 2013
    Cypress tx
    9
    Re: my results
    Quote Originally Posted by proavia View Post
    Your correct. I raised the TA from i think 40 to 80. Cant remember now as it took about 5 days to get all in order. It was what the math chart advised.
    20000 gal
    single speed pump
    well water
