Results 1 to 7 of 7
Thread: Tim the Tool Man Syndrome
    Jul 2016
    Milton
    18
    Got the new pool all plumbed and wired up this evening, you can see the pump and filter I bought in my signature. these were not the ones offered in the kits with the pools. I wanted a 220 volt pumps these were the ones I bought. I didn't think they were overkill, I new they were larger then what is normally on an AG pool.but didn't think they would be too big. Anyways, when I started the pump it will suck my skimmer dry. I had to shut the valve on the discharge side to slow the flow . Im running about 10psi on my filter . has anyone installed a 2nd skimmer on a AG pool?
    Justin N.W. Florida
    27' AGP 54" Depth K-2006 test kit
    Hayward super pump 1H.P.
    Hayward Star Clear C12002
    Apr 2013
    Sacramento, CA
    2,769
    Re: Tim the Tool Man Syndrome
    I'm not the person to help you but let's bump this
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Are you sure your water level is high enough?
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Try raising the water level in the pool to between 1/2 - 3/4 the way up the skimmer opening. A 1hp pump is not too much pump for your pool, but if the water level is too low it will react just that way.
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Milton
    18
    I have the water level right at the middle of the skimmer, I'll put a little more water in the pool and report back.
    Jul 2016
    Milton
    18
    I love a simple fix!! I put another 1-2 inches of water in the pool and everything is working great. Thanks for the help. It looks a little higher then I thought it should be though. The level is about 1 1/2" from covering the skimmer opening. Is this still acceptable?
    Jul 2009
    Houston, Texas
    9,380
    As long as the skimmer is able to collect debris it is fine.
    Love TFP? Become a
    TFP Supporter!
