Thread: Center drain
    Center drain
    We got our above ground pool installed last year and finally got to swim in it at the end of summer. My question is that I'm suspicious that the center drain may not have the liner cut from it since I don't feel any suction from that drain. Should I feel suction from it? If it hasn't been cut, is it something that we can do ourselves, or do I need to call someone in to take care of it? (I really don't want to call the company that put in the pool because I had a terrible experience with them.)
    Any advice would be appreciated!
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    West Michigan
    108
    I'm sorry I don't have an answer for you. I didn't know AGP had center drains in them. Does that mean it is hooked up to the filter system? Or is it only to drain the pool? I know Matt or someone will know. Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The drains are designed to prevent entrapment, so you won't feel any suction.
    Mar 2007
    San Rafael, CA USA
    12,082
    To check out the circulation in your pool you can add Party Blue or a similar dye (something that will contrast with the color of your liner) and you can see if the dye gets sucked down to the bottom drain of if it stays on the surface and just goes to the skimmer. The dye will dissipate (break down) within a couple of days and you can have fun in a colored pool in the meantime!
