Thread: Return inlet eyeball fittings - need to find the right part
    Jul 2016
    Kansas City, MO
    12
    I have an in-ground gunite pool and need to replace my return inlet eyeball fittings but I am having difficulty finding the right part. I am hoping someone here can help me find the right part. Please see attached pics.
    1st Pic is of the Wall fitting just for reference.
    2nd Pic is of the fitting that attaches to it along with the eyeball (eyeball not pictured).
    As you can see from the pic, the diameter is 1.75". I found a few 1.5" fittings but not a 1.75" that would thread into my wall fitting.
    Any help would be appreciated
    Pool: 15000 Gallon, Inground Gunite/Plaster Pool (Kidney shape), Sta-Rite P6RA6E-205L, Polaris Cleaner, Built circa 1998
    Jul 2013
    Waxahachie, Tx.
    446
    Re: Return inlet eyeball fittings - need to find the right part
    I would check with the pool builder if possible
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    You could check with INYO Pools they have buckets of eyeballs. And good tech support folks.
    Apr 2015
    tucson, arizona
    1,126
    Push-In PacFab Style Pool Eyeball with Inserts, White, This may help. The 1.5" refers to the size of fitting that goes into wall. Yours looks like an insider which is pushed in instead of threaded
    Jul 2016
    Kansas City, MO
    12
    Thanks for all your replies. So, after doing some more research and playing with the Hayward eyeball return fittings, here is what I have found:
    1. My wall fitting is actually a standard 1.5" (please disregard my note above about it possibly being 1.75").
    2. My wall fitting does not come off and it also does not have slits to insert a tool to remove them.
    3. So, now that I don't need to replace the wall fitting, I just need the ring and the eyeball. While the Hayward ring is a perfect fit and screw in perfectly (without the eyeball), the eyeball was a little too big for it to fit in the wall fitting. So, I can't screw in the ring with the eyeball. See pics below. The new one I tried is a Hayward.
    Where can I find a 1.5" return fitting with a smaller eyeball? I think that will do the trick.
    Attachment 52779
    Pool: 15K Gallon Pool, Inground Gunite/Plaster Pool (Kidney shape), Hayward SP2302VSP Pump, Polaris Cleaner, Built circa 1998
