Thread: Easy Touch Name Programming
    aguyindallas's Avatar
    Apr 2016
    Little Elm, TX
    127
    So my PB connected my landscape lights to the "Solar" button on my control panel. My two options to operate them are to push the "solar" button on the panel or use the "Aux" button on the features section of the app. That's fine and it works. My question though is can I name the "aux" button something else in the app?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    Re: Easy Touch Name Programming
    I assume you have Screen Logic.. if so, close the program and it should take you to the start up page.
    Select Configure ScreenLogic which takes you to the welcome page
    Select Configure Screen logic again which takes you to the first programming page
    Select next and you should see all your circuits
    highlight the aux circuit you want to name
    At the bottom of the screen you can select a dropdown menu where you can select a new name (Pool Light)
    Select finish and then start ScreenLogic.
    Apr 2016
    Little Elm, TX
    127
    That worked. Thank you!
    11.5K Plaster, level spa, Salt with Pentair Equipment.
    Apr 2016
    Little Elm, TX
    127
    I have another question. There are several circuits in my feature menu that do not (and likely will never) get used. Am I able to "hide" those in the app so it only displays the relevant ones?
    Jul 2014
    Bedford, TX
    7,520
    Yes..
    On the same page where you changed the name, off to the right is a drop down box that says some like ScreenLogic Display.. Just highlight any circuits you do not want (one at a time) and select the drop down of "don't show"..
    Apr 2016
    Little Elm, TX
    127
    Thanks AGAIN! I was able to hide the unused circuits AND move my landscape lights from the "features" section to the light section of the app.
    Perfect!
