Thread: baquacil to salt conversion help
    We have a 30ft round above ground pool that is 2 years old and has been baquacil only. We decided to switch to the salt system and bought the salt system and the needed cholorine to help with the transition. Our pump is totally apart and clean from all residue. We will be adding new sand and we need to know what else it will take to convert our pool over. Our pool is halfway full of water, and we have not removed the cover or done anything yet. Any suggestions or help would be greatly appreciated.
    kb
    matt
    18x40 oval aboveground pool
    21,900 gallons
    21" Hayward sand filter 1-1/2hp
    Troy, Illinois(st. louis, mo)
    30,416
    Re: baquacil to salt conversion help
    Hi, KB,
    Welcome to the forum. A recent set of test results for your pool would be helpful. How does your water look?
    Generally, if your water tests fine and looks crystal clear, it's time to change the sand and you're converted.
    Welcome to TFP!
    First you need to do a more or less standard spring opening. The only difference is that you don't want to balance anything other than PH and TA.
    Once the pool is full and the pump is running, you can follow the conversion instructions at Pool School.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yikes, the process calls for changing the sand AFTER converting.
    Will they have to change the sand twice?
    Read carefully. I don't think they have started the conversion at all yet.
    If the sand is already changed, but the baquacil has not been removed from the water yet, the sand would need to be changed again at the end.
