Thread: Bugs getting through sand filter
    We have a Sta-Rite T-210WF sand filter with a 1 1/2 hp pump on our 16x32 above ground pool. We have been getting some sand at the bottom of our pool and now there are bugs getting stuck in my saltwater chlorinator (which is after my sand filter). I pulled the top off the filter today to see if there were any visible channels but I didn't see any.
    Originally when there was sand in the pool, I was thinking that maybe one of the laterals may have cracked, but that would not explain how bugs are getting through.
    Any thoughts?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: Bugs getting through sand filter
    Welcome to TFP! Good to have you here
    I'm sure you rinse after backwashing of course, but if it were mine, there's two possibilities I would check:
    Spider gasket may have failed (usually you would see some other problems though) but easy enough to check. Here's a video that explains changing one: How to Replace a Spider Gasket on a Multiport Valve - INYOPools.com
    If the gasket looks fine, then you could deep clean it per this procedure: Deep Cleaning a Sand Filter
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Thank you. I was wondering if it may be the spider gasket. I'll have to replace it to see what happens.
    needsajet's Avatar
    Jan 2016
    4,230
    Bugs coming through pipes, start with the spider gasket. Makes perfect sense, hahaha
    Aug 2014
    Northern IL
    4,615
    Ewwww.
