Results 1 to 19 of 19
Thread: buildup......
    Dec 2015
    Redding, CA
    22
    buildup......
    I have recently cleaned my filters, all my chem levels are great and in the range recommended. Yet it seems that after about 3-4 days there is a little brownish/greenish buildup in the surfaces of the pool. So I've been brushing the pool 1-2 times a week. I guess my question is am I missing something? It seems that brushing 1-2 times a week is more then I expected....or is this pretty standard?
    What might be helpful as well is that my pool has these little popup heads that are jets and they rotate and kick up whatever is on the bottom of the pool in the shallow and deep end. So when my pump is running it determines how hard the jets go, for example when I set the pump speed to 4 the jets are working strong, when the pump is on speed 1 the jets are weaker.... So I'm guessing that instead of a pool sweeper the previous owner had these installed to kick up and clean off the surface of the pool and then it get's filtered via the pool filter. Does anyone have this setup? Any recommendations on how to use this right and dial it in good I would love your input!
    22,151 gallons, IG, Pebbletech, Pentair Quad D.E., Pentair IntelliFlo Variable Speed
    Built in 1993 then pebble tech applied in 1999, TF100 kit w/ Speedster, Basic K-1000
    38,275
    Re: buildup......
    Define "chem levels are great". We need test results
    Sounds like you have an in-floor system. I had one at previous house. Downside is that they do not keep the pool very clean and you have to run the pump on a high speed for a long time to get the dirt into the skimmer or floor drain.
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    Ah...that's what it's called - In Floor system. So should I be looking at a pool sweeper setup at some point?
    Test results:
    FC - 5.5
    CC - 0
    CH - 325
    TA - 110
    PH - 7.5
    CYA - 50
    38,275
    Re: buildup......
    If you run the pump at high enough speed for long enough, mine actually did keep the pool fairly clean (dirt would gather in a few spots and I would brush it toward the drain.
    The alternative is to get some other kind of cleaner.
    Has you FC dropped too low in the past? Just want to be sure that you may not have algae starting.
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    Ok thank for info. Long enough at high speed would be 1 hour? 2 hour? more a day? any recommendations?
    FC - The lowest it's been is 4.5 and the highest is 7.5, it's been in that range for at least 3-4 months
    38,275
    Re: buildup......
    I thought they recommend a full circuit around for each jet, so you can figure it out based on hire many zone, how long they are on and how much they turn each time. I think it is usually many many hours, 8+ which is a big downside.
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    ok thanks. Let me know if you have any suggestions on the other issue as well. Thanks!
    38,275
    Re: buildup......
    What other issue?
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    You asked for my test results in regards to the buildup and me brushing 1-2 a week. You had wondered about if there was beginning to be a algae buildup..... etc.. So I guess my question is, is this normal (brushing 1-2 a week and it doesn't take much for buildup) or am I missing something?
    Feb 2015
    Chandler AZ
    927
    Re: buildup......
    A few pictures of the infloor pop-up heads and the water distribution valve may help identify which brand of infloor cleaner you have. Knowing what brand may assist in determining how long it takes the heads to run through a full 360 degree cycle at a given rpm.
    You will need to run at a high rpm to clean the pool using the infloor forgiven amount to of time. Probably not full speed - but probably at or above 2800 rpm. Once floor cleaning is complete, you can run at a much lower rpm for the rest of the needed run time.
    EDIT:
    You should still brush the entire pool surface once a week. But there probably shouldn't be a discernible buildup on the walls on a consistent basis. Have you considered preforming an OCLT to rule out any organic issues?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    38,275
    Re: buildup......
    Hard to say if the build up is just dirt from inefficient in-floor cleaner or the signs of algae.
    Any sliminess?
    You could Perform the Overnight Chlorine Loss Test to see if there is a high demand.
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    For some reason the browser is not letting me upload pics. The brand of the infloor pop up heads are "Caretaker 99".
    Ok on brushing once a week. When I do brush it is noticeable that it's been brushed as it kicks up a brownish cloudy substance.
    Quote Originally Posted by proavia View Post
    EDIT:
    38,275
    Re: buildup......
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Feb 2015
    Chandler AZ
    927
    Re: buildup......
    Ok - Caretaker 99 by Jandy
    Is the water distribution valve a 5 port or 8 port? I think the default time per zone is 45 seconds - and is probably based on pump being on highest speed (3450 rpms). Slower speeds will results in less flow, hence the zone will stay on for a longer period of time - and may not provide enough velocity to clean to your satisfaction.
    Here's the manual in case you don't already have it: Caretaker 99 Manual
    You will need to experiment with run time and rpm to determine parameters to keep the pool clean to your standards. Based on this experimentation, you can then determine if additional run time is needed at a lower rpm to satisfy your filtering/skimming needs.
    I still think an OCLT would be to your benefit.
    Gene
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    I did OCLT and it stayed the same - 6. My guess is now that with the infloor system that the poo is not getting properly cleaned. So I will run the pump on higher speeds for longer periods. I may get a pool vacuum as well to keep anything from building up on the bottom.....
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    Any other suggestions from anyone? All my chem levels are great (posted above) and the water isn't crystal clear, I would say its about 80% clear. I had some leaves on the bottom of the pool today so I went ahead and swept them up and in doing that, a cloud formed in the water right where my net went. So it seems there is a bit of sediment on the bottom and it get's kicked up. This also happens when I turn my pump on speed 4 (3200 rpm). So I guess my question is would the sediment buildup on the bottom be a result of the the infloor system not doing a great job? Would my main drain not be functioning while pump is running? Is a pool vacuum the next best step to vacuum all the sediment up? Thanks in advance.
    38,275
    Re: buildup......
    Since you pass the OCLT, there may not be any algae to worry about.
    I think you just need to run your pump at a higher speed and for longer so that the sediment stays in suspension and is eventually trapped by the filter.
    Your floor drain might be sucking water, depends on your plumbing setup.
    Feb 2015
    Chandler AZ
    927
    Re: buildup......
    Can you post a pic of your equipment pad - showing all the valves and other equipment?
    Gene
    Dec 2015
    Redding, CA
    22
    Re: buildup......
    Sorry for delaying my reply. I have good news. I run my pump at speed 4 for 3 hours every morning then it goes back to lower speeds for 5 hours and my pool is looking clear as clear can get. It took a few days to get all the sediment kicked up and into the filters but it's looking really good for around 4-5 days. So I think i've got it all sorted now. Thanks for your help everyone!
