Thread: Should I even bother with the CH?
    Jun 2016
    West Lafayette, Indinana
    14
    So I understand the only way to lower my CH is to drain and add new water... My tap water is hard, just tested it at 360 CH... Is it worth my trouble drain and fill up pool with water that's run through my water softener? Will that soft water have other things that I don't want in my pool? Or should I just be okay with the high CH and take care of my other numbers? Vinyl pool so I know it's not a huge deal.
    My latest numbers.
    CYA was 50 this morning too.. Just noticed that not shown.
    16'x48" Coleman AGP Filled 2016-07-16. FlowClear Filter Pump #90401E (???? gph?), Intex LED Fountain.
    30,421
    Re: Should I even bother with the CH?
    Too much Calcium is a problem.
    The suggested range is 250 - 400 so it's a good idea to manage your pool to stay within that range.
    38,303
    Just start using your softened water to top-off and keep the pool full so you slow down how quickly the CH rises.
    Jun 2016
    14
    Okay, sounds like I'll add it to my todo list. First want to get the TA down. I'm hoping that goes quicker now that I finally got some muriatic acid. That pH-minus stuff only lowered my bank account...
