Thread: Getting the hang of it...
    Jun 2016
    Boston burbs, MA
    45
    So July 4th weekend was my Independence Day from the pool store and pool boy. Since then, despite a mishap with the pool boy showing up and dumping a bunch of stuff in my perfectly clear and balanced water (ugh!), I've finished a SLAM and have effortlessly maintained it.
    Current readings are:
    FC 4.0 (it was 7.5 this morning, and time for me to add some bleach)
    CC 0
    pH 7.5 (added MA this morning to bring it to 7.2, then the kids aerated for me and brought it back up)
    TA 120 (down from a high of 150)
    CH 275
    CYA 40
    Should I continue to chip away at the TA, or am I ok here? I need to add some water too -- it's been blisteringly hot here in Boston, and not a drop of rain. Water level is getting close to uncomfortable, so I'm gonna hook the hose up in the morning and add 2-3 inches.
    I've said this before -- but this forum is the most wonderful, helpful, forgiving and accepting in the whole web world. So thank you.
    Rhonda, Outside of Boston, MA
    20k gallon IG gunite circa 1984, very old/stained/worn out plaster finish
    4820 Hayward DE filter, no idea on the pump... will figure that out!, T-100 test kit, Speed Stir is the BOMB!
    *Researching options to refinish Spring 2017!*
    Jul 2015
    Central Valley CA
    1,108
    Re: Getting the hang of it...
    If your pH is not rising too fast then you can leave the TA where it is. If it seems like you are going through a lot of MA then continue to push it down.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Boston burbs, MA
    45
    Thank you for the quick response! Actually, 7.5 seems to be my sweet spot, so I'm just gonna watch it...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Good plan. Nice numbers.
