Thread: Pool Newbie in need of kick start
    Jun 2016
    Stafford, VA
    4
    I recently purchased a short sale home with an ~25000 gallon inground pool w/ DE filter. This is the 2nd year I've owned it and I've finally managed to get all the leaves/debris out (previous owner did not have appropriate cover and apparently hadn't opened pool in some time- the amount of leaves in the bottom was unbelievable!). I've figured out how to work all the plumbing, breakdown and clean DE filter, vacuum floors, etc. I've also managed to get the pool opened myself this year and have gotten it pretty clear. I'm finally at the point where I'm aiming to balance the pool chemistry and that has led me to this wonderful site. Hope to learn a lot and then ultimately contribute to the forum. Thanks for having me!
    Inground gunite pool
    ~30,000 gallons
    DE filter (Purex Triton FNS-Plus Vertical Grid, 60 sq. ft.)
    Jul 2015
    Central Valley CA
    1,109
    Re: Pool Newbie in need of kick start
    Welcome to the forum
    I see you already have a thread started about getting the water balanced. I will post over there to keep that thread going so I don't duplicate suggestions and cause confusion. I am sure you will get a few more suggestions over in that other thread in no time.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    38,539
    Welcome to TFP!!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    Nice job reading up and getting started getting your pool under control!
