Thread: First go of algae using TFP
    Feb 2016
    Roselle, IL
    39
    New to the TFP method this season. Everything was going along fine until today. Just pulled my cover to find green algae, I guess my first step is a SLAM right?
    FC = 1.5
    CC = 0.5
    pH = 7.8
    TA = 120
    CH = 100
    CYA = 30
    I have had plenty of readings like this before, just not sure why algae now. I target my FC to 4 and check every other day. Things were fine Sunday afternoon. Thoughts?
    13,200 GAL Aqua Leader Influence 54" AG | Heyward S244T Sand Filter (250 Lbs.) | 2-Speed Hayward Pump | RayPak 206 Cupro Nickel Natural Gas Heater | Hard Piped | Kontiki 2 Suction cleaner | TF-100 Test Kit w/ SpeedStir | 2016 Install | Chicago Suburbs
    30,405
    Re: First go of algae using TFP
    At some point, your FC slipped and it allowed algae to get a foothold.
    Yes, it is now time to SLAM the pool.
    Feb 2016
    Roselle, IL
    39
    After 30 minutes I have no FC loss.... Could it be something other than algae? I guess I will vacuum and brush to see where to go from next.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    To verify if there is something organic in your pool you can perform the Overnight Chlorine Loss Test.
    Your FC is below minimum for your CYA, FC/CYA Chart, in the test results you posted. When FC drops below minimum the pool is unsanitary and bacteria and algae can grow.
    Feb 2016
    Roselle, IL
    39
    Still no FC loss after 2 hours, going to see how we look overnight
    Feb 2016
    Roselle, IL
    39
    Lost 2.5 FC overnight, so I returned the pool to an FC level of 12 at 7am this morning before work. Got home to a FC of 7 at 4pm. Not losing FC fast enough to see a drop in 30 minutes, so should I just keep bring it back to shock level until I pass an overnight test?
