Thread: Pool math chlorine question
    Jul 2016
    Valparaiso, IN
    27
    When I enter 8% chlorine into the FC table the calculator it reads "Weight", however when I enter 12.5% the word changes to "Trade". Just wondering what the difference is and why that difference is noted?
    Rolo
    Aqua Leader 27' (54") 17,100 gallon, Hayward SW 256T sand filter, Hayward 2 hp 2-speed pump, water testing with a TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Pool math chlorine question
    Bleach sold for laundry use is sold by weight percent of sodium hypochlorite. That's 6% and 8.25%.
    Liquid chlorine sold for pools is typically listed as Trade % which is really a volume %. That covers 10%, 12.5% & 15%.
    The difference between weight and volume percent have to do with the specific gravity of the solution. It changes the FC calculations slightly.
    Matt
    Sep 2016
    North Kansas City, Missouri
    5
    That is very helpful, JoyfulNoise. Thank you. I didn't realize that the laundry version was listed as weight %.
    I just got a quote from a chemical supplier for 12.5% Sodium Hypochlorite. 12.5% by weight is 15% by volume.
    Not your typical pool. 130K, in ground pond, 30 mil BTL liner (polyethylene), 3 EasyPro PS10E Eco-Series Ovation Pond Skimmers w/ EasyPro EP9700 Large Mag Drive Pond Pump, Max Flow 9700 Gallons-Per-Hour. Lined with river rock and other rocks. Originally had plants, set up as a natural pond. Kansas City, Missouri. TAYLOR K-2006 TEST KIT COMP CHLORINE FAS-DPD. https://goo.gl/photos/jMWp7VnNvbANyfuQ6
    May 2016
    Troy IL
    476
    Interesting. So the 8.3% great value bleach at walmart is actually probably a higher percentage of sodium hypochlorite than the 10% liquid chlorine they were selling in the pool section for a while. That would explain why when I switched from the liquid chlorine stuff to the laundry aisle stuff, I didn't have to alter the timing on my stenner to meet my target FC level, even though going from 10% to 8.3% made me think I should have had to use more.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    1.45 oz 8.25% provides the same amount of chlorine as 1.16 oz of 10% or 1 oz of 12.5%.
    Support the site
