Results 1 to 8 of 8
Thread: Is my pump too large?
    Jul 2015
    Arnold, Mo
    4
    Question Is my pump too large?
    I've been thinking my pump is too large for my pool. It's 2HP and the water really flows from the jets, my kids have trouble swimming against the current. When I came home today my pump motor was running but not pumping and it was making more noise than usual. I think it's done after 13+ years of Missouri weather. Should I replace it a 1 1/2HP?
    Matt
    16x32 rectangular in-ground with vinyl liner. 5ft deep end , 3ft shallow. Sand filter, 2hp pump, 2 skimmers, 2 jets & 1 main drain. Liquid chlorine & tablets.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Is my pump too large?
    Welcome to the forum!
    If you have no high flow rate needs (e.g. spa, waterfall), then almost any pump will do. I run my pool on a 1/2 HP 2 speed pump. So I would say a 1 1/2 HP is still too big. Do you have a controller or timer to turn on and off the pump?
    Mark
    Jul 2015
    Arnold, Mo
    4
    I use a timer and run it about 14 - 16 hours a day.
    mas985's Avatar
    Pleasanton, CA
    11,737
    14-16 hours is probably way more time than you need too. My pump averages about 4 hours per day in the summer.
    Pool School - Determine Pump Run Time
    If you are interested in a two speed, here are a couple of good choices:
    Hayward MaxFlo XL SP2307X102
    Pentair SuperFlo 340042
    But you would need to add a two speed timer to switch speeds automatically. Or you could switch speeds manually.
    Mark
    Jul 2015
    Arnold, Mo
    4
    What is he advantage of the two speed? Efficiency?
    38,274
    Saving $ on electricity by running at the lower speed most of the time.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, low speed reduces energy costs by over 75%. High speed of your old pump probably used between 2000-2500 watts. The pumps above on high speed will use 1000-1400 watts and on low speed 250-300 watts.
    Mark
    Jul 2015
    Arnold, Mo
    4
    OK thanks!
