Thread: Brown sediment in bottom of pool
    Jul 2016
    Winnipeg, Manitoba CANADA
    1
    Angry Brown sediment in bottom of pool
    I have a salt water above ground pool. This year I have been battling with a brown sediment in the bottom. I vacuum every day; usually straight to backwash every 3rd day and it continuously returns. My chlorine level was very high to start and is slowly coming down. All other levels are correct. I use test strips and my pool supply place numbers run very close. They said I could try algaecide but not sure if this is the right direction. They tell me to backwash when I vacuum which I have done but each morning it is there. Filter was new late last year and properly cleaned before installation this year.
    Aug 2015
    NE AL
    40
    Re: Brown sediment in bottom of pool
    Do you use a sand filter?
    If so, is it possible that you may have a cracked lateral that is letting small amounts of sand back in the pool when the filter is turned on.
    30,421
    Have you cleaned your filter more than once?
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Get your own test kit...like TF 100 sold here. Trust your own numbers...
