Thread: liquid Chlorine/Clorox and 3" tabs near filter?
    Jul 2016
    Yorktown, NY
    6
    I used the liquid Chlorine to raise my FC; should I be using both the liquid and the 3" tablets? or just the liquid chlorine and/or bleach?
    36 x 18 rectangular in-ground liner, 28,000 gallons, Hayward Pro Series Sand Filter
    Jul 2015
    Central Valley CA
    1,109
    Re: liquid Chlorine/Clorox and 3" tabs near filter?
    Liquid only unless your CYA levels are a bit low then the tabs can be helpful but that would be a rare occurrence.
    If you look at the PoolMath link the bottom of that page there is an effects of adding chemicals drop down. Assuming you have your pool volume in the calculator it will tell you how adding any chemical or tablet will affect the water.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
