Thread: Return jet collar stuck
    loomer's Avatar
    Jun 2016
    Marlton/NJ
    25
    Question Return jet collar stuck
    I have a new house, with a new pool and have noticed an issue with the one and only return in my pool. It appears that the threaded part to a return jet collar broke off and is stuck in the return pipe. Hence making it impossible to attach a new return fitting into the pipe. Was wondering if anyone had any tricks, or ways of getting this piece out. There is nothing sticking out from the pipe to grab hold of with needle nose pliers, and I have tried in vain attempting to turn it by hand. It's stuck in there pretty good.
    19000 gal rectangle 16x32 IG vinyl pool - 1.5" pvc - Niagra Sand filter -
    1 skim/1 return -120v 1HP Pentair SuperFlo pump
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Return jet collar stuck
    Not sure how to get it out but a 90 Degree rubber elbow with a hose clamp works in place of the jet if you need something there to create circulation
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    loomer's Avatar
    Jun 2016
    Marlton/NJ
    25
    Quote Originally Posted by cj3737 View Post
    There is nothing there to clamp a hose onto. There is the face plate, and that's it..
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    MAy have to replace the return jet... Id wait till pool closing when you lower the water
    13500 gal
