Results 1 to 13 of 13
Thread: Leaking filter
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Leaking filter
    I noticed a little water on my pump/filter pad last evening but it wasn't much. Today I find a small stream of water spewing out of the neck of the filter in a seam, and it is a few inches under the top valve on the filter. I run my pump on low 99% of the time, only on high when I throw some grass in while mowing. My pressure is at 10 psi, and never has got above 12. It is under warranty and I have left the builder a message but not heard back. Is there anything that I should be concerned with while waiting??
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    30,431
    Re: Leaking filter
    That is a major problem and needs to be fixed. I am sure your PB will have no problem satisfying the warranty.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    PB said they would take care of it soon as they can get one in. In the meantime I have by passed filter and just running straight back to pool. I will switch back and forth from recirculate to filter as needed. Thanks Dave!
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    How long can I go without filtering and just bypassing my pool??
    Mark
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    Is it normal for a sand filter to swell a little bit when switching from low pump speed to high??
    Mark
    Dec 2014
    Houston, Texas
    134
    Re: Leaking filter
    You can circulate the water in the pool without filtering forever. You will however have a swamp on your hands sooner than later. Just keep an eye on the chlorine level and adjust as needed to maintain 1-5ppm until the issue is fixed.
    Yes it's normal for the filter to swell under pressure.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    I have been switching back and forth between recirculate and filter. Circulate for a few hours and filter for a few hours. I am running pump on low, because it wont spew the water out like it does on high. Today is the first time I ever noticed it swell though. Could that have caused the split in the seam. Thanks Joel!
    Mark
    Dec 2014
    Houston, Texas
    134
    Re: Leaking filter
    Not likely the cause of the leak. Could've been a weak spot in the mold from the factory or more than likely from the gasket under the clamp.
    Edit: I'd blame the SWG but I don't need the flood of PM's that would result from it
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    Why blame the SWG? How can that hurt a plastic component?
    Mark
    Dec 2014
    Houston, Texas
    134
    Re: Leaking filter
    Twas an inside joke....
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    PB is dragging his feet getting out here to replace filter. I've been told the new one is in, they just don't have time to do it. My question is, with a filter that is leaking at seam, cause bubbles to be coming in from the return jets? I've only seen little bubbles when the SWG is on, but now it is all the time, and more of them.
    Mark
    Dec 2014
    Houston, Texas
    134
    Re: Leaking filter
    The crack in the filter will cause air bubbles but only a short time after the pump starts up for the day due to the leak draining the water in the filter while the pump is off. After the pump starts the filter is on the pressure side and if there's a leak you'll see water. Excessive or constant air bubbles are from the suction side. This starts at the pump lid and everything forward leading into the pump such as valves, plumbing joints and even the front drain plug on the pump.
    Start with the simple things first. Inspect the O-ring on the front drain plug. Lube or replace as needed. If it's bad and you don't have a replacement you can Teflon tape the plug threads to hold you over till you get a replacement. Check the pump lid O-ring, make sure you don't have any dried debris stuck to the underside or in the channel it sits. Stretch it a little bit to see if you see cracks in the rubber or if you get black all over you it's time to replace. After that check all connections and valves if present, people here like the water hose method (have someone run water over the connections while you look at the pool to see if the bubbles stop) I personally like the sound method, prime everything up, let it run for a few minutes then shut off the pump and put your ear to every connection listening for the leak.
    GL!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: Leaking filter
    Thanks Joel, I know what to look for now!!!
    Mark
