Thread: Test results are in and where do I go from here?
    May 2016
    Abilene/Tx
    42
    Hey everyone I did a full round of tests this month and am off...I got back from vacation and this is what the tests say
    FC 1
    CC 1
    Calcium 450
    Alkalinity 260
    CYA 50
    PH 8.3
    I plugged things into the pool math calculator so it tells me what to do but I kind of want to know what to tackle first? I assume I can't just poor acid, chlorine, borate, baking soda etc in all at once right?
    15ft by 30ft kidney style? Inground plaster pool w/8ft attached spa. Shallow end is 3ft and deep end is 9ft. Pentair clean and clear plus (thinking 420?)shooting for BBB method.
    38,428
    Re: Test results are in and where do I go from here?
    Lower the pH
    Raise the FC
    That is all.
    You just need to wait a few minutes between chemical additions. Do NOT add any baking soda or borax ... you do not need it.
    Since the FC dropped so low, you might want to raise it up and Perform the Overnight Chlorine Loss Test to see if there is a need to follow the ShockLevelAndMAINTAIN Process.
    May 2016
    Abilene/Tx
    42
    OK I can handle that what is better muriatic acid or dry acid?
    Apr 2016
    Moundsville wv
    55
    iv'e always used muriatic acid! i've been using this system since i opened up my pool this year and my pool is balanced. i just for a weeks vacation, i brought my fc up to 25 ppm which my shock is about 20 however, i came back to a clean and balanced pool. i also have a skimmer net which was cleaned out every other day so, im sure that helped as well.
    2015 built myself~15x30x52(15k)AG,vinyl liner~Hayward166t (16'' sand filter w1 Hp pump) Hayward sp1580 power-flo lx series~taylor2006 test kit
