Thread: Jandy Laars Temperature Control Assembly
    Apr 2015
    Granada Hills, Ca
    24
    I have a temperature board that I believe is bad.
    Jandy Laars Temperature Control Assembly - R0011700
    I have checked for 24V from the metal spade connector on my 24V transformer to the 24V terminal on the ignition control box, and I do not have 24V.
    My question is: is there an independent way to check or bypass the Temperature Board to prove that the board is bad?
    Thanks
    Sandy
    Apr 2015
    tucson, arizona
    1,116
    Re: Jandy Laars Temperature Control Assembly
    Lite2 Look at the technical page
