Thread: What test kit do I need?
    May 2015
    Fullerton, CA
    635
    Looking at water in the next week or so, need to get a test kit here. Which do I buy and what else would you recommend?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: What test kit do I need?
    Taylor K 2006 or TF-100... see the comparison in my sig block
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    38,274
    The TF-100 is the better deal with great customer service from tftestkits.net
    The SpeedStir is also a great addition.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What Jason said, in addition if you are a supporter here you can get a discount on the TF-100, see the link in the upper left of this page
    38,274
    True, if you never used the code from when you became a Lifetime supporter, you should still be able to get that discount on the TF-100.
    Aug 2015
    Orlando
    116
    Quote Originally Posted by Titan7 View Post
    I would add in the salt test kit too, looks like you will be installing SWG, but that's my preference. TFTkits sells it too, save on shipping later buying it all at once.
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
