Thread: Pool Tech Maintenance: Community Pool Chemistry
    Dec 2015
    Doral, FL
    48
    My obsession with testing has leads me to the conclusion that even though pools are sanitized and kept to a healthy pH by most pool techs. The TA, CYA levels and CH levels are often way off. Our community pool had ZERO CYA, CH of 90, TA of 30, pH of 7.2, FC 15..5, CC <0.5 . The tech had just added chlorine 4 hours earlier.
    I have checked several friends pools and keep finding this problem of CH being super low and TA usually very low also and to some extent the CYA higher than it should be most of the time. Is this common in the industry? Our health department only requires FC, pH, CYA and flow rate readings.
    Is it cheaper to just throw more chlorine in than to add CYA? Baking Soda is cheap; seems they don't want to use that either. Calcium Carbonate is not inexpensive; are they afraid to use it due to the risk of staining/cost?
    Your thoughts on the matter are appreciated
    17.5K gal,31'x15' IG plaster, Depth 4'-6', Built 2015, Pump: Jandy Pro Series Model FHPM 2.HP -2-Spd, 88gpm Turnover 3.3 Hrs; Heater: Jandy JE Heat Pump Model 2500T SWCG: Jandy AquaPure Ei Series Mod. Apure35 Max Output Hypochlorous Acid = 420 g of FC per day = 0.2666 ppm per hour; Filter: Jandy Pro Series Model CS 200; Cleaner: Jandy MX8, Test Kit: Taylor K-2006 Salt; Stenner 45M1; City Water:Doral, FL.
    domct203's Avatar
    Jun 2015
    CT
    3,600
    Re: Pool Tech Maintenance: Community Pool Chemistry
    Quote Originally Posted by panamax53 View Post
    Our methods here apply to residential pool only. Different communities/counties/states have different rules and regulations for public pools, and often require a CPO.
    I'll comment on this though.... that 15.5ppm FC to 0ppm CYA ratio is ridiculously high, and would destroy swimsuits in no time, as well as dry out skin, hair, etc.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Dec 2015
    Doral, FL
    48
    I read somewhere that a few pool companies don't even use CYA, they simply use more chlorine. Understandable, but why would they keep TA so low at 30? Could that low a level keep the pH at the bottom range of 7.2?
    May 2016
    Phoenix AZ
    128
    I would be less concerned about the TA at this point. That is a ridiculous (potentially unsafe?) level of chlorine with a true zero CYA. Is it possible the CYA is in the 20-30 range, but you just can't read it? Because that would make a lot more sense.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    The pucks and trichlor are acidic and drive down PH and TA.
    38,548
    Also low CH does not matter unless the pool is plaster.
